Tranny temp gauge sending unit. Can I do this???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazerBoy, Mar 8, 2001.
  1. BlazerBoy
    BlazerBoy 1/2 ton status
    639
    Chicago IL.
    I just bought a tranny temp gauge, and I am dont have the time or a welder at the moment to drop the pan and weld in the sending unit. Is it possible to pipe it into the tranny lines?? If so which line should I go into the line leaving the tranny or the return line after the stock & aftermarket coolers? Thanks for you help and sugestions are welcome.
    BlazerBoy
    http://generalblueballs.coloradok5.com
  2. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Yes it is possible, why, with only one sensor either line will work.
    Use both lines and use a switch to select which sensor you are reading.
  3. BlazerBoy
    639
    Chicago IL.
    sweet..... I really like that idea.. You can never have enough switches hehe O.k so now where can I get another sending unit for my b&m guage?? Any ideas?? Thanks Executioner
    BlazerBoy
  4. dyeager535
    26,982
    191
    Why not just tap into one of the line pressure ports on the side of the tranny? There should be a couple of plugs already threaded in. Pull one out and get an adapter to put it in. I personally don't like cutting tranny lines unless I absolutely have to.
    Dorian
  5. Executioner
    Feb 22, 2000
    1,530
    Pep Boys have them, but uder a different brand name.
  6. BlazerBoy
    639
    Chicago IL.
    Yeah, that is what I was planning to do. I will check it out and let you guys know how it goes thanks... :) I really hope pep boys has them
    BlazerBoy
