tranny temp gauge.
Discussion in 'The Garage' started by Jonny-K5, Oct 19, 2003.
  1. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    just picked up a digital trans temp gauge and i'm a little leary about the sending unit. the instructions say to get a brass T fitting and splice it into the line going to the cooler. i dont like this idea.sounds like a PITA. has anyone done it this way? it says i can find the parts at any auto/ plumbing store. i kind of doubt this as well. should i just stick it into the pan? whats the best way to do it? Thanks
  2. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    Well I've heard of people puting the sender in the pan. Also seen an article in petersen's, they tapped of the main line pressure to run a temp and pressure gauge. Personally I'd do it that way.
  3. ducttape114
    ducttape114 1/2 ton status
    Aug 1, 2002
    990
    Orcutt Ca
    you will get a more acurate reading if you do it in the pan. thats how i did mine. geting it to seal was a bit of a pain but it seals fine now.
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
  5. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    id did it in the line..but my damn sender doesnt work..guage tested ok but i get no reading sao im guessing it was bad..havnt replaced it yet...but anyway..if you have a small tube cutter its not that hard at all..my B&M one came with all the fittings to do it though..
  6. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    did you guys put anything inside the pan to seal it? like tack weld a nut? or just tap the pans metal and use alot of goop.
  7. heavy4x4
    Aug 28, 2002
    3,270
    I just tapped the pan (can get about 1-2 threads in /forums/images/graemlins/crazy.gif) and then J-B welded just on the outside.
    No leaks from the sender, despite what the mess of fluid on the underbody of my truck may suggest /forums/images/graemlins/smirk.gif /forums/images/graemlins/rotfl.gif.
  8. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I just installed one in my s10 this weekend (700r4). I put the sender in the pressure test port in the driver's side of the tranny. It had a 1/8" NPT plug in it and the sender was also 1/8" NPT. It worked out perfect...like it was ment to be there (and I am sure it was). The test port has fluid comming right from the pump before it goes to the cooler. TCI has pics of the locations on their website if you can't find it.
    My truck runs about 175deg just normal driving. It has a 195 t-stat and the cooler lines go to the rad and then to a tube and fin in front of the condenser.
  9. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    The easist place to put it is in the test port as above post says. It will work fine and give you a pretty good idea on how the trans is running. Plus it makes properly adjusting the TV valve real easy. BUT. The best place is in the pan. The sensor in the pan will tell you the temp of the bulk of the fluid..
    Putting a sensor in the test port or the cooler lines just gives you the temp at that point. Depending where it is it may be hotter or cooler than the fluid in the pan.
    What you mainly need to know is if the fluid in the pan is too hot and cooking in there. Trans fluid starts breaking down rapidly at constant temps over 180 degrees. When everything is warmed up good constant temps of 120 -160 in the pan are ideal for long trans life.
  10. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    just installed my temp gauge yesterday. 10 minutes down the freeway the temps climb over 200 and hover around 205-210. is this because i have the sending unit in the test port?thus making the temps higher. i have a stock tranny cooler. ya think i need a bigger one?
  11. heavy4x4
    Aug 28, 2002
    3,270
    Yes, that port will read a little higher than what's in the pan because it's coming right from the torque converter. So, you should be fine.
    Sure wouldn't hurt to put one on. About $45 and you'll have a happy tranny.
  12. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The reason your trans temp runs that hot is because that is the temp your motor is running at. Your coolant is heating your trans fluid in the radiator trans cooler (is it really a cooler if it heats the fluid...how about calling it a heat exchanger). If you want the trans temp to be lower than the motor you will have to disconnect it from the radiator heat exchanger and just run a cooler in front of the radiator.
  13. 77Jimmy
    77Jimmy 1/2 ton status
    Sep 3, 2002
    661
    Atlanta, GA
    Hi. You might want to check link below out. I put the tranny temp guage in the pan and was running in the same temp range as you (200-215) before replacing the fin/tube w/ the stacked plate cooler. /forums/images/graemlins/grin.gif
    click here
  14. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    just read the link, thanks for the info guys. i think i'll go with a new big cooler. /forums/images/graemlins/grin.gif
