Tranny Temp Guage Installation "Q"
Discussion in 'The Garage' started by big jimmy 91, Apr 12, 2005.
  1. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    Can someone tell me "exactly" where the pressure test port is on a 700 R in my 91 Jimmy
    I would like to install the mechanical guage I just picked up soon
  2. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Driver's side, forward and above where the shifter shaft protrudes the case (IIRC). Tell us how this goes for you. I've thought about doing the same thing, especially since the 700R4 is so pressure sensitive. Gonna need about a 300 PSI though.
  3. big jimmy 91
    Feb 21, 2004
    639
    What do you mean by pressure sens. and 300 psi. , is that the amount of press at the test port? :confused:
    I would hate to do something wrong and screw up a functioning tranny :doah:
  4. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    i dont think you really want the temp gauge at the pressure port, it will be very slow to react to temp change, and by the time it's overheated you will be s.o.l.
  5. big jimmy 91
    Feb 21, 2004
    639
    Are there any tranny "guru's" out there that know the best place to install a temp. sending unit?
  6. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    You can't put a mechanical sender in the test port. The test port is 1/8NPT and I bet your mechanical sender is more like 3/8NPT. You will either have to splice a T into the cooler line or put it in the pan by welding in a bung.
    FWIW this is the pump press test port (where I have mine and it works fine):
  7. big jimmy 91
    Feb 21, 2004
    639
    I had a look under the truck and it does look like my sender is too large to fit.
    I guess it will have to go inline with the cooler lines
  8. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    best place is in the pan. besides, id much rather put a bung in the pan than splice in the cooler lines, but thats just me.
  9. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    I have also put mine in that port. It works fine, no problems at all.
  10. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Take a look at the pics in my Webshot link in my signature. I think the pics are in my "modifications" folder.
    I put my sender in the pan...passenger side, towards the front. All I did was drill a hole, tap it (which only gave me 2 or 3 threads), thread the sender in, and JB Weld around it. Never had a leak.
    Oh, and I put it in the pan because I feel that's the best place. That's the temperature of the fluid that will be running INTO the inner-workings of the tranny. The cooler line out of the tranny is at the temp after it gets heated up by the torque converter, etc. The cooler line into the tranny tells you what the temp going into the pan is, but that just heats up as it sits in the pan. The pressure port is not a good place to use, in my opinion.
