tranny temp guage question
Discussion in 'The Garage' started by big jimmy 91, Apr 3, 2004.
  1. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    I want to install a tranny temp. guage in my truck to keep an eye on things when towing and driving hard.
    What type of guage , where does it get the temp. reading from , what is the normal operating temp of the 700R4?
    Or is this really required?
    Any info would be appreciated , thanks
    /forums/images/graemlins/ears.gif
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Here's what I'm running.
    What type of guage
    Autometer 2 5/8" tranny-temp gauge, electric sender.
    Sender is mounted in the pan.
    Mine stays right around 150 degrees. It will sometimes edge up near 180. Anything over that and I start worrying/taking it easy.
    I highly recommend getting one. Knowing how your tranny is running during certain conditions is very important. When I'm on the freeway and my 700R4 isn't in OD-lockup (ie, still in OD, but the converter unlocks, like when going up a grade and it needs a little more gas), I can literally watch my temp gauge climb.
  3. cybrfire
    Dec 15, 2002
    15,143
    574
    Iowa
    There are several places you can locate the sending unit. I prefer mine in the line that comes out of the tranny. That way I know how hot my trans is running. Some people like it in the pan or the other line. These will tell you how hot the trans fluid is before it goes into the tranny I think. Not necessarily how hot the transmission is running. From what I have read your trans shouldn't run over 180. Anything above that and you begin to shorten the life span of your transmission.
  4. big jimmy 91
    Feb 21, 2004
    639
    How is the sending unit mounted to the pan , or line?
    Does it go in-line , or do you put a hole in the pan etc.
    /forums/images/graemlins/ears.gif thanks
  5. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    think befor getting the B&M one from sumit..the damn sender i got with mine was no good, never had time to get it replaced, ive had the gauge in there for probobly half a year and its never worked lol..
  6. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Pan: Weld in bung with proper thread
    In-line: Either use some fittings in one of the lines or put it in the test port on the left side of the tranny. This was all dicussed about 1 week ago (with pics)...just do a search to find it.
  7. Judd
    Judd 1/2 ton status
    Sep 27, 2002
    175
    N.E. Ga
    I'll second that. I also bought a B&M electric tranny gage that didn't work. I used a Autogage 2 5/8 mechanical water temp gage as my tranny gage this time. I drilled a hole in the rear of the pan and welded a bung in. Works great.
    As another poster has already said,,, keep the temp under 180 degrees if possible. Around 160-170 degrees would probably be perfect, hot enough to burn off condensation and cool enough to last a long time. Once you get to 200 degrees, tranny life really goes down hill fast.
    I converted my AC condensor into my tranny cooler and my temps have yet to get over 150 degrees. I live in Ga. so I'm not too worried about the fluid being too cool. Beside that, I know for sure the fluid coming out is plenty hot at times,,,,, you can't touch the line going to the cooler it's so hot. That should burn the water off I reckon.
  8. duece21
    duece21 1/2 ton status
    Jan 18, 2004
    501
    Aurora, CO
    Sh*t I just purchased the B&M tranny temp gauge, /forums/images/graemlins/doah.gif oh well if it doesn't work I'll just tie it to a rock and then send it back to checkers /forums/images/graemlins/rotfl.gif
