Tranny temp guage
Discussion in 'The Garage' started by 4X4HIGH, Nov 19, 2003.
  1. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    On a 700R4 tranny where is the best place in the tranny pan to install a mechanical capillary gauge sender? I just removed the pan and there isn't much room for anything to protrude into the pan. The fitting I need to install is 1/2" pipe. I figure I will make up a steel fitting to weld onto the pan for the brass 1/2" NPT fitting to screw into then the gauge's capillary tube will screw into it. About the only place that looks feasible is in the rear portion of the pan since that seems to have the most available area but I am open to suggestions.
  2. Judd
    Judd 1/2 ton status
    Sep 27, 2002
    175
    N.E. Ga
    I'm going in from the front of the pan just because I don't have enough line to go further back. I might be able to place the bung on the drivers' side of the pan but I will not be able to make it to the back of the pan for sure. If you have to, you could always add a spacer {pipe} so that the bulb is pretty much flush with the inside of the pan. Reckone I'll find out for sure this weekend.
    At first, I thought I would not be able to reach the pan at all with the line supplied. I rigged up a three way fitting with compression fittings to place in the line to the cooler. It would work, it just looks like a Jerry rig though.
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I've got a sender plumbed into my 700R4 pan here.
    Mine isn't as big as what you're putting in though. It's a 1/4" NPT sender and goes into the pan about 1/2".
