Tranny Temp Sender Unit Install
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BigBadJap, Jul 30, 2003.
  1. BigBadJap
    BigBadJap Registered Member
    May 23, 2003
    76
    Alberta, Canada
    I was thinking about adding a tranny temp gauge to my Jimmy and was wondering if brazing/welding the temp sender unit into the pan is the only way to do it?
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    1) B&M tranny temp gauges come with a t-fitting that you put in your cooling lines right next to the tranny. This involves cutting the line with a tubing cutter and putting in the compression piece.
    2) You can thread the autometer sender into the pressure port on the driver's side of the tranny.
    3) This is what I did. I've got an autometer with an 1/8" NPT sending unit. I drilled a hole in the pan, tapped it with the proper tap, screwed in the sender, then went around the sender on the outside with JB weld. Works great! Pic 1 Pic 2
