tranny torque rod
Discussion in 'The Garage' started by 83PJW, Apr 21, 2003.
  1. 83PJW
    83PJW 1/2 ton status
    Aug 18, 2002
    160
    leavenworth, ks
    350 turbo to a 205 t case set up, do i absolutly need a torque rod? i have been splitting my trannies in 2 lately. suggestions need help.
  2. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    yes.
    Figure that every part GM has made in the last 50 years was designed by an engineer. More importantly it was approved by a costing accountant which means the engineer had a dang good reason for wanting it.
  3. JDNobodi
    JDNobodi 1/2 ton status Premium Member
    Oct 9, 2002
    3,008
    197
    Santa Maria, CA
    Did GM make torque rods for the TH350, NP205 combo? All I have seen is torque rods for NP203s and NP208s, and an extra frame mount for the NP205s. Granted, I've hardly seen the undercarriage of a 80's K5 which may have the torque rod.
  4. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Yes GM did make a torque rod for the TH350/NP205 combo. The guy who rebuilt my tranny told me to attach the torque rod and showed me 3 cases he had laying around that had broken because the owners forgot to attach them.
    There is also a "L" bracket that goes from the tcase to the frame. They are kinda difficult to fine though. I made an "L" bracket with 3/4" steel stock and plan on attaching it to the frame, you just have to use a bushing between the bracket and the frame.
  5. JDNobodi
    Oct 9, 2002
    3,008
    197
    Santa Maria, CA
    Yes, I known of the L braket, and I was refereing about it in my quote. I have about three of these mounts laying around. The mounts can be found on frist gen Blazers and pickups and early second gen blazers and pickups with a NP205. It seems by 1977, GM stopped putting these L brackets on the 4x4s because my brother's 77 did not have the bracket on his 465/NP205 combo. In fact, his tranfer case did not have the holes drilled in the side of the case where the L bracket or a torque rod would mount. /forums/images/graemlins/1zhelp.gif Anyway, I collected quite a few 205s, but most are from 69 to 73, so I only seen the frame mount.
