Tranny/transfer case mounts?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dyeager535, Jan 10, 2001.
  1. dyeager535
    26,979
    Can these be purchased through LMC or GM still? I need the (if different from other 4wd adapters) two squarish rubber blocks that bolt to the adapter between the SM465 and NP205 as the tranny mount(s). I assume that all other 4wd adapters use the same mounts, but here at work I don't have any catalogs...a GM part # would be handy too if they are still available! Thanks
    Dorian
    My K5 and Chev/Olds links: <A target="_blank" HREF=http://yeagerd.home.mindspring.com/index2.html>http://yeagerd.home.mindspring.com/index2.html</A>
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i do not have the part # but yes you can still get them at gm if they do not have them then go to your local tranny shop they should be able to get them 4 you.
    s.smith 77blazer lookin 4 mud
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Last ones I bought came from a corner parts store. You can also get them in polyurethane. ORD may carry them.
  4. dyeager535
    26,979
    I was thinking about polyurethane..I like the concept, but I've seen enough "feet" on the adapters that are broken that I would be leery to use them in that location due to their "hardness". Anyone out there had experiences with them good or bad??
    Dorian
  5. Danivek
    Danivek Registered Member
    Dec 18, 2000
    24
    El Paso Texas
    Please for the love of god DO NOT USE THE POLYURETHANE TRANNY MOUNTS. I broke the feet on my adapter and have had the hardest time looking for the adapter.
    P.S. if any one has the adapter for the SM465/208 combo please let me know
    danivek@worldnet.att.net
