Tranny & Transfer Case Questions
Discussion in 'The Garage' started by Polaris, Dec 28, 2002.
  1. Polaris
    Polaris 1/2 ton status
    May 30, 2002
    1,182
    Rhinelander, Wisconsin
    Yes, I did a search. I could be looking for the answer all weekend! Turns out my transfer case is shot. I have a 700R4/NP241 combo. We found last night that my driveshaft was too short in such a way that it bent a 2nd mainshaft (I'm so sorry tRustyK5 /forums/images/graemlins/frown.gif). We thought the tailshaft of the case just needed to be sealed up better but when I went to remove it, the tailshaft came off in 3 pieces. I need my truck running and doing it reliably as this is our family vehicle. Here are my options for parts right now:
    208 case $75 - will it bolt right in to my 700R4??
    For a 4 hour trip and a cheeseburger I can get a TH400/203 combo. What would it take to put that in? Thanks.
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    The 208 as long as it came off a 700r4 will bolt right in. I think even the driveshafts are the same. All 208's had a speedo cable and 89 was the only year for the speedo cable on the 241 then they went to the VSS speed sensor.
    To go to the 400/203, you will need new driveshafts, a sorce for vacumme for the modulator, possible exhaust mods to clear, most likely have to drill new holes in the frame to mount the crossmember.
  3. Polaris
    May 30, 2002
    1,182
    Hey Wayne... I like your sig line. So how does a person get around that speedo cable/VSS issue? Go without a speedometer?? I'm inclined towards the 400/203 combo for durability as I do wheel. Exhaust mods aren't so big of a deal with a pipe bender and a welder /forums/images/graemlins/wink.gif talk about fringe benefits of being married to a shop manager. We can lengthen/shorten shafts too, I think, but I'm not sure how well they are balanced til we can try out the first attempt.
    Thanks!
  4. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    The 208 will bolt up, But I don't know if the 241 Adapter will work I should think the output shaft would be the same. If the 241 Adapter won't work I have one I could send your way.
    If you go with the 400/203 you'll loose the OD and you drive shafts mite not fit right but then they mite not right with the 208 the 208 is a slip yoke and you 241 is as well. I don't know about the 203 but I think they came both ways.
    I would also worry about the 203 being a full time t-case.
    Also if you went with the 400 you could get a 205 to mate up with it pretty easy I would think.
    Eric
  5. Polaris
    May 30, 2002
    1,182
    Oooh... hubby stopped on the way home and arrived with a 241 in the trunk of the car. We'll throw that in for now... thanks guys.
  6. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Sounds like the rear shaft is running in a bind condition. Maybe see about grinding the yokes a little bit to alleviate it.
    Larger joints will usually run a steeper angle. This would require (at least) a larger slip yoke, and a larger end on the driveshaft.
    A slip-yoke eliminator kit would shorten the t-case, and therefore relax the angle a little bit. You might even be able to fix your busted t-case with one of these kits!
    I'm quite sure a TH400/203 is longer than a TH700/241, making the angle worse. Not to mention losing OD, and has a shallower low range (2:1 vs 2.7:1).
  7. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Good thing those parts were free huh?/forums/images/graemlins/smile.gif You're gonna be a T-case expert if you keep this up...and a driveshaft expert!/forums/images/graemlins/grin.gif
    I hope you have better luck this time.
    Rene
