tranny / transfer case
Discussion in 'Parts & Trucks Wanted' started by clarkekent, Mar 6, 2002.
  1. clarkekent
    clarkekent Registered Member
    Sep 26, 2000
    69
    NY
    The tranny and transfer case are cracked on my 72 so I'm open to ideas. Plarts should be located somewhat close to NYC. Let me know what you got and how much.
  2. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    you running auto or manual, if auto you can use any 2wd tranny and change the output shaft, use the one form your 4wd.
    as for the np205(i asume that's what ya have), you can get a 10spline Xcase and change the input shaft. the 10spline are not very desirable and a lot cheaper.
    if your Xcase ADAPTER is from a th350/np205 and broken, get in line. i am also looking for one/forums/images/icons/smile.gif.
    ARQ.
  3. clarkekent
    Sep 26, 2000
    69
    NY
    I had an 350/205 setup but am open to new ideas like 400/208, possible manual. I need to get this truck back on the road ASAP.
  4. hotstuff
    hotstuff 1/2 ton status
    May 4, 2000
    239
    connecticut
    located about 6hrs from you is a rebuilt t-350 with transfercase(fixed rear yoke) the tranny has 4000 miles since professionally done if you wanted to check it out take a drive down, drive it then I'll help you remove it. takes about 2hrs to remove. $950 for both,let me know or take whole blazer with 6000 miles on rebuilt motor (350) runs great but carb needs to be cleaned.$1500 for all
    hotstuff
  5. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    i have a TH400 and NP208 for sale.....I removed them from my suburban to go with a 4 speed manual....they both are in good shape...ill include the crossmember and maybe front shaft as well. E-Mail me if you are interested.
    Brian
    82 BURB 38.5's, 10/14 bolts, 6" lift, SM465/NP205
  6. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    1huge1ton, has one on the forsale section. check it out. it's a darn good price for it too. too bad i am too far away.
    ARQ.
