Tranny vent line.
Discussion in 'The Garage' started by afroman006, Jun 25, 2005.
  1. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    I assume the little plastic tube poking out of the top of a TH400 is the vent line. Whatever the case may be, I broke mine off, and need to know how to replace it. Thanks.
  2. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    I broke one off befor. I just stuffed it back in the hole and smeared some JB weld around it and called it good.
  3. LongIslander26
    LongIslander26 1/2 ton status
    Jun 25, 2005
    256
    Park County, Montana
    Vent tube
    It's not a life or death thing unless you drive the thing up to the rocker panels in water, otherwise it just needs to allow the hot air out when you're driving it.
  4. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Some just push in (most) and some need a twist. Kind of like front axle differential breather tubes... some twist in and some you just smack with a hammer.
    Most TH350s had a metal one on it, pick yourself up one of those.
  5. afroman006
    Aug 21, 2002
    2,876
    Well I plan on dunking this bitch so I really need to make sure it can breath above the water. I'll check out a th350 I have thats still in a truck. Thanks.
