tranny vent line
Discussion in 'The Garage' started by Jays Beast, Oct 7, 2003.
  1. Jays Beast
    Jays Beast 1/2 ton status
    Aug 7, 2002
    538
    Chandler, AZ
    Ok, these may sound dumb but is there a way to replace the tranny vent line with out removing the tranny from the truck? Also what holds it in there mine broke off, (on a 700r4 tranny) looked like the fitting was plastic /forums/images/graemlins/eek.gif ?
  2. Jays Beast
    Aug 7, 2002
    538
    Chandler, AZ
  3. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    It is just a plastic breather. Find a piece of metal tubing, steel, copper, whatever the same o.d. and and knock a small length, 1"-1 1/2" long in place of the plastic one. Then add some rubber hose up into the engine compartment somewhere, out of water, mud, goo's, harm. /forums/images/graemlins/eek.gif
  4. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    It's plastic and has a flared end. It slips into the case b4 the front pump goes in and the flare keeps it from coming on thru the case hole.
    Either a snug fitting metal tube or a perfect case for J-B Weld if you can get it clean enough.
  5. Jays Beast
    Aug 7, 2002
    538
    Chandler, AZ
    Thanks for the info /forums/images/graemlins/thumb.gif
