Tranny Vent
Discussion in 'The Garage' started by Jays Beast, Sep 14, 2004.
  1. Jays Beast
    Jays Beast 1/2 ton status
    Aug 7, 2002
    538
    Chandler, AZ
    The plastic tranny vent tube broke on my 700r4. I am wonder if the other side of the plastic tube(inside the tranny)will it hurt anything, if it falls inside the tranny?
    Also if I have to pull the tranny how hard is it to get to the vent tube?
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    you just hyave to take the pump off to get to the other side of the tube. If the tube just broke clean you should not have a problem with it getting in to the tranny. If you do take the tranny out insted of replacing with another one tap the hole use pipe fittings so you can then run a rubber vent line this also is better for off roading so you can put you vent line up high
  3. Jays Beast
    Aug 7, 2002
    538
    Chandler, AZ
    Ok, does anyone know of a good technical book about a 700r4.
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i only use the ATSG books /forums/images/graemlins/waytogo.gif
  5. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    i rebuilt mine with a chilton manual
