Tranny weights
Discussion in 'The Garage' started by Emmettology 101, Dec 6, 2002.
  1. Emmettology 101
    May 9, 2000
    8,126
    FL
    What are the weights of the following trannies?
    Th350
    Th400
    700R4
    200-4r
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    Thanks!!! There really isn't much difference between the three!
  4. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I though a th400 was HEAVY but your saying a 700r4 is even heaver so if you replaced a 700 witha 400 it shoudl feel faster right?
  5. u2slow
    May 9, 2001
    2,217
    BC Canada
    I doubt you'll notice 20lbs of truck making any difference in the quickness department.
    Assuming the same axle ratio, the TH700 will be quicker with the 3.06:1 first gear.
  6. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I'm guessing those #'s are without torque converters?
    Also does anyone know the weight of a 4l80e?
  7. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    depends on if you are holding it up by yourself. /forums/images/graemlins/rotfl.gif
    nathan
  8. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,127
    56
    Powell, Wy
    In my experience my 700R4/np208 was ALOT lighter than my TH400/NP241. Both had fluid in them and the TC attached
