tranny woes
Discussion in 'The Garage' started by scrappyk5, Feb 12, 2003.
  1. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    well i pulled the 700r4 tranny out, had a mechanic replace
    every seal in the front of including the bushing , and its
    still leaking from up somewhere inside the bellhousing area
    either from the torque converter or the housing.
    anyone ever had this problem ?
    is the case itself cracked ?
    is the torque converter cracked?
    it doesnt leak straight down form the shaft, the leak
    kinda runs down each side of inside the bell housing area
    right in the middle like as if the converter os throwing it.
    i need to fix this thing asap. help /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
  2. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    Earlier 700r4s were bad about blowing the front seal. There is a clip that helps hold the seal in. If you take off the pump you should enlarge the oil drain hole behind the seal (get a pro to do it). You could also have a burr or something where the pump mounts.
