tranny wont shift
Discussion in 'The Garage' started by 81k5blzr, Dec 1, 2004.
  1. 81k5blzr
    81k5blzr Registered Member
    Oct 7, 2004
    9
    st. marys, GA
    My turbo 350 will not engage into any gear. Please help me identify my problem and offer solutions.
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    it won't enguage in any gear or wont shift from first?
    did it just happen with no warning?
    first i would check your linkage on the side of the tranny, then id pull the pan and make sure the linkage is good inside the tranny. if those aren't it, it may be a pump problem.
    i had one do almost, if not the same thing. i was moving sand around with my plow and shifted into reverse and nothing, drive nothing, we checked everything, all was good, nice red color in the fluid. i got pissed (the polls were on either side of my door so i couldn't get out) and put it in reverse and it enguaged and went, i was stupid to stop and then it didn't work again, again i punched it and it took off, i backed it out of the way. the funny thing is this was 3 weeks after i bought the truck and the PO said that his buddy rebuild the trans and said its unbreakable, i guess im hard on stuff /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif
    ive been too lazy to tear it apart to find what it was but my best guess is the pump and im betting you have the same problem.
    there was no noises or anything.
  3. diesel4me
    Jul 24, 2003
    17,577
    943
    Massachussetts
    Its a long list of "mightbees"
    1.Its low or empty on fluid!
    2.Modulator could be blown(usually it wont upshift,but its doubtful it would make it not move at all)
    3.flex plate is broken,or the bolts to the convertor fell out.
    4.tourque coverter
    5.main input shaft broken
    6.clutches are shot
    7.filter clogged,or fell off into the pan,blocking the fluid to the pump(pump could be junk also)
    8.valve body,or its gaskets
    9.manual linkage fell off inside tranny where it hooks to the valve body
    10.valve body bolts loose or fell into the pan.
    11.pressure regulator valve sticking,or screen inside tranny to it plugged.
    12.leaking clutch pack seals
    could be more reasons too--sure the t-case didnt get shifted to "neutral" by accident??--does it make any noises??--did you hit a rock with it??--did it happen while driving,or after it was parked??--need more info!! /forums/images/graemlins/1zhelp.gif
