tranny ?
Discussion in 'The Garage' started by hd-10, Apr 18, 2004.
  1. hd-10
    hd-10 1/2 ton status
    Jan 31, 2004
    188
    lemoore, ca
    i have a th 350 tranny and the reverse is not woking to good on it sometimes it would kick in good and then the next time i put it in it would not work at all. so if any ideas out there let me know thanks
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    check the fluid level
  3. hd-10
    Jan 31, 2004
    188
    lemoore, ca
    fluid level is good it almost wants to work but just wont and if its on flat surface then it works put real jumpy
  4. hd-10
    Jan 31, 2004
    188
    lemoore, ca
    i took the back drive line off and checked if it still worked and it did, so for some reason when there is a load it will not work any kideas?
  5. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the clutch hub is probably worn and it letting the steel plates spin instead of holding them still. thats why sometimes it works and some times doesn't /forums/images/graemlins/dunno.gif
  6. hd-10
    Jan 31, 2004
    188
    lemoore, ca
    started working on the truck again and it will not move at all now forward or backwards i have the front drive shaft off and went thourgh 2H to 4LO and in 4LO after giving it a lot of gas it finally moved about 2 inch's but the front yoke didn't move could it be the t/c that is bad and not the tranny? any help would be great thanks.
  7. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    most likely if there is no noise coming from the converter, then its not the converter. time to get it rebuilt /forums/images/graemlins/deal.gif
  8. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Time for a conversion.
  9. hd-10
    Jan 31, 2004
    188
    lemoore, ca
    i was wondering about the transfer case being bad not the torque converter. so for the confusion
