tranny
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CarsonRoen, Apr 24, 2000.
  1. CarsonRoen
    CarsonRoen Registered Member
    Mar 7, 2000
    16
    WA, USA
    help!!! my transmission will not engage. i think it is because it doesn't have any fluid, is that possible? also i was told to add Dexron II, is that the same as Dexron II or what? if someone could please help me, i would be very thankful.
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    First of all, why doesn't your tranny have fluid in it? Have you checked? Or are you guessing? And how long has it been without it? If you've been driving without fluid, you may as well tow it to a tranny shop and get them to put a new one in. Dexron III is the updated version of Dexron II. We'll need more info too: Year, motor, tranny, transfer case, etc....
  3. BillR
    BillR 1/2 ton status
    Mar 15, 2000
    164
    Flagstaff, AZ
    No fluid WILL do just that. Dextron is the same with a 2 or a 3 after it. It sounds like you have another problem if you have no fluid, though...
    Blazin' in Flagstaff
  4. Whii338
    Whii338 Registered Member
    Apr 24, 2000
    35
    got any more info?year,engine, tranny type etc.? First check your fluid..in park with the engine running and warm then post the vital stats of your truck..lotta people here can help maybe not me but somone can.
  5. 6.2 man
    6.2 man 1/2 ton status Premium Member
    636
    Curtis , WA
    Did you check the tranny fluid ? it sounds like it's leaking and you need to keep it filled . Use dexron II in it by the way I live about a 120 miles south of you .
