Tranny???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by txguy, May 6, 2002.
  1. txguy
    txguy 1/2 ton status
    Sep 4, 2001
    114
    Round Rock (Austin) Tx
    Afternoon all,
    There is a small hole that is a seep hole, or ?? on the base of where the starter mounts. I have been getting more and more fluid leaking out of there. Any ideas? Is this the tranny? Engine? All the above?
    Tony
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I beleive the hole you're talking about is the little hole on the bottom of your flywheel cover. It sounds like your rear main seal has let go.........
    It could also be oil leaking down from a pooched valve cover gasket.
  3. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    What is the fluid that's coming out ? Oil, ATF, mixture of both ? It could be the rear main leaking on your engine, or possibly the front seal on your tranny.
