trans case oil change?
Discussion in 'The Garage' started by kustom71, Dec 23, 2003.
  1. kustom71
    kustom71 1/2 ton status
    Mar 14, 2003
    117
    NJ
    Hey anybody know off hand what bolt i should take out to get the transfer case to drain its a 203.When i look at it theres no drain just a pipe plug that i guess is the oil fill hole?Should i pull out any bolt that is at the bottom of the case or is there a certain bolt on some part of the case that should be pulled out?When i pulled the trans apart from the transfer case fluid came out the bottom hole where the adapter was bolted to it but now that its back in the truck other holes look lower than that one.maybe a bolt on the rear output shaft of the case or should i pull out one nearest the chain part of the tansfer case???Any help is appreciated!
    Thanx
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Been awhile....I think there is a rear cover, remove one of the lower bolts, and it will drain outta there....
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Yep, exactly what he said, pull the lowest bolt on the backside panel and it will drain /forums/images/graemlins/thumb.gif
  4. kustom71
    Mar 14, 2003
    117
    NJ
    thanx thats what i thought when i looked at it the lowest bolt is on the backside cover.
    Thanx again /forums/images/graemlins/thumb.gif /forums/images/graemlins/truck.gif
