Trans Conversion
Discussion in 'The Garage' started by WickedBlazer, Jan 17, 2005.
  1. WickedBlazer
    WickedBlazer Newbie
    Jan 17, 2005
    Hillsborough NJ
    Yeah I juss wana know if you can and how. I need to convert my transmission into a stcik . i have a 700r4 it keeps blowing i went through 3 i juss wana know if i can do it and how to move the 4 wd shifter thanks
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Yes it can be done. If you swap from a 700R4/208 (or 241) to a 465/208 (or 241) the shifter will not have to be moved. You will only have to swap all the clutch stuff, add a third pedal for the clutch, add the shifter in the tunnel, swap transfer cases (or swap input gears), and you will need to swap the tranny and tcase adapter.
    Harley
  3. k5blazin
    k5blazin 1/2 ton status
    Dec 19, 2004
    262
    Elizabethtown, PA
    In the tech section of the home page there is a write up on how to do this conversion.
