Trans cooler lines
Discussion in 'The Garage' started by seattle73k5, Jul 7, 2005.
  1. seattle73k5
    seattle73k5 1/2 ton status
    May 6, 2005
    210
    San diego/Camp Pendleton
    Does anybody know what size AN fittings to use for transmission cooler lines coming from the tranny? it is a 700r4 trans, the lines I have are jimmy rigged and are leaking so while I am at work tommorrow I figured I would make some new lines but I don't know the size needed.
    thanks in advance.
  2. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    they're not AN.. its flare.. its NPT coming out of the tranny.. 1/4 npt i believe.. it has an adapter coming out of that from npt to flare... i went steelbraided with AN so i got the 1/4 npt to #6 adapter and eliminated the factory adapter...
    iirc correctly the flare size to the factory fitting is 5/16...
    http://www.tciauto.com/tech_info/cooler_fittings.htm
