trans cooler overkill?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BillyBob, May 16, 2001.
  1. BillyBob
    BillyBob 1/2 ton status
    Feb 23, 2000
    557
    Dumont, NJ
    Just wondering, but can you actually overdo it with the size of a trans cooler? I have a 700 R4 in my 84 (been rebuilt) and it already has a cooler in it. But it's a super small weenie cooler. About what size should I get? I'll probably want something for towing, and something that could hold up to the megashifter if I wanna have some fun [​IMG]. Any ideas?
    <A target="_blank" HREF=http://billybob.coloradok5.com>http://billybob.coloradok5.com</A>
    If it ain't leaking oil, it ain't my truck![​IMG]
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I believe the general opinion here is that bigger is better when you're trying to keep a 700r4 cool...........I run a Tru-Cool 22,000 GVW auxilliary cooler in mine. It's similar in construction to the B&M. Try to stay away from the aluminum tube/fin design- thy're not as tough and don't have any built-in bypass if a blockage ocurs in the cooler.
    <font color=red>PHOTO ALBUM-</font color=red> <A target="_blank" HREF=http://albums.photopoint.com/j/AlbumList?u=1289798>http://albums.photopoint.com/j/AlbumList?u=1289798</A>.......<font color=blue>TRUCK & HIKING PICS</font color=blue>
  3. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    From what I have read. You should get one that is rated at 24,000 GVW. Check out this site you might be able to tell what yours is rated at by looking at the sizes.........Dan <A target="_blank" HREF=http://www.perma-cool.com/Catalog/Cat_page05.html>http://www.perma-cool.com/Catalog/Cat_page05.html</A>
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    The only time I think you can overdo a trans cooler is if you live in cold climate and have a huge cooler that is not also running fluid through your stock raidator cooler. Transmitions have a temprature operating range just like an engine. If trans fluid is too cold it doesn't flow well and can cause high pressures which can damage seals, cause harsh shifting and other problems over time also cold thick fluid is very hard on the pump.
    Many people who run large coolers in cold climates use a thermostat valve that routes the fluid through the stock radiator cooler to keep it warm when the weather is very cold. And when it gets warmer it bypasses the stock cooler.
    I use my Blazer with a 700r4 to tow a 18 foot ski boat, small travel trailer, and toy trailer. I am running a 18000 GVW heavy duity cooler. It works good and keeps the trans in its opreating range no mater what the temp is.. It is the smallest cooler I would recomend running. I also use it in conjunction with the stock cooler in my radiator.
    Most coolers are designed to be used along with the stock cooler. But if you decide to bypass the stock radiator cooler. Get the biggest cooler you can find.
  5. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    A friend of mine runs an old freezer condensor. This thing is as big as the rad. He has run this setup since 1977 when he bought the truck new. He currently has about 400,000 miles on the factory TH400. The trans has not shown any odd behaviour from this oversize cooler and he lives in the northeast. I personally run a 28,000GVW cooler in my truck. I'm not sure that you could overcool any trans let alone a 700.
  6. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Here is the combo I plan to run in the next month. For tranny cooler I'd like to go with the B&M 28,000 GVM cooler.... http://www.permacool.com/Catalog/Cat_page25.html.
    89 K5 Silverado
    <A target="_blank" HREF=http://mudfrog.coloradok5.com>http://mudfrog.coloradok5.com</A>
  7. mrivan
    mrivan 1/2 ton status
    Sep 10, 2000
    123
    Coastal Mts. Or.
    I always figured that you could use an aoto air conditioner radiator for a super duty tranny cooler ,I pull a fire wood trailer with my 454 conversion 2wd Blazer . As we live in the coastal mts. of OR. the grades are super steep and with a fully loaded trailer of green wood that fluid gets hot quick even with the fairly large cooler I installed......
    Mrivan..............
  8. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    You can over cool a trans! (its hard to do, but possible)
    A trans needs to get to at least OVER 100 deg f. to boil out any water that may have acumulated. Water and oil do not mix and water is not a very good lubricant. A trans is vented to outside air, so when it gets hot, the hot air has somewhere to go. When it cools down, it will suck air and moisture in the air into the trans.
    In colder climates, sometimes running fluid to the cooler BEFORE the radiator will help keep the trans in opperating temps. The cooler will pull out the excess heat, then as the trans fluid flows threw the radiator, the coolant will raise or lower the trans fluid temps as needed.
    -In hotter climates, towing or long trips. run the cooler AFTER the radiator
    -Normal Torque converter temps are around 300 deg f.
    -Radiator/engine cooling is primary, all other coolers come second.
    -700R4s need a external cooler of some type.
    -Make sure your radiator is in good working order
    -Normal opperating temps of a trans (depending on where the temps are measured) should be around 170-250 degs f.
    -300+ deg. f. is to hot for a typical auto trans.
    Twiztid
  9. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    I was going to use my AC condensor as a tranny cooler since I pulled the AC out to do on board air. Is this a bad Idea?
    You call that dirty!?
  10. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    IMO
    yes
  11. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    I am running the B&M 24,000 tranny cooler. Came with everything I needed and keeps it cool.
    SK-15
    J**P...it's whats for dinner!
    <A target="_blank" HREF=http://SK-15.coloradok5.com>http://SK-15.coloradok5.com</A>
    Roads? Where we're going, we don't need any roads!
  12. prjt_blzr
    Mar 4, 2001
    352
    COS, CO
    I would not use the A/C condenser from the vehicle for a trans cooler. The passages seem to be restrictive. The one in my post was from an old freezer and had larger tubes that were placed closer together than the A/C condenser. It was also a headered setup so that a blocked tube would not stop the fluid flow. I've got no idea what exactly this thing was from as this was done in 1977. When I put my cooler on the highest GVW cooler that I found was from B&M. It is rated at 28,000GVW. I think that I got it from summit.
  13. FastEddy
    FastEddy 1/2 ton status
    Feb 3, 2001
    182
    southeast manitoba, canada
    A friend of mine has been running an a/c condenser for a trans cooler for a couple years in his off road contraption with a 700R4 and it has been trouble free (knock on wood) we mainly are crawling (or flying) through mud and the truck see's more low speed but with 40 inch tires etc we figured bigger is better. I do understand what others are saying about blocked tubes but if you have particles that big in your trans you have some major trauma anyway happening inside. our fluid gets changed a few times a year (usually after being totally submerged, looks more like a strawberry margarita than trans fluid. just my 2 cents...ED
