trans cooler?
Discussion in 'The Garage' started by digity, Nov 13, 2005.
  1. digity
    digity 1/2 ton status
    Oct 10, 2004
    184
    13
    Brentwood Ca
    Ok just had my 700r replaced. I'm putting in secondary tranny coooler today. Can anyone tell me which line from the radiator is the return line. Upper or lower. She's a 1990. Thanks. :doah:
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Bottom line into the radiator is in FROM the trans, upper line goes out TO the trans.
    To confirm, start engine cold, place trans in drive for 10-15 seconds, shut off engine (put trans back into park!) :wink1: Touch lines at radiator. The "from trans" line will be the warmer of the two.
  3. tpi_boy
    tpi_boy Registered Member
    Feb 27, 2005
    7
    Vancouver
    you can leave trans in park on a 700 to verify flow direction.
