trans. Cooler
Discussion in 'The Garage' started by georgiared84, Jun 12, 2003.
  1. georgiared84
    georgiared84 1/2 ton status
    Sep 5, 2002
    487
    Austell, Georgia
  2. georgiared84
    Sep 5, 2002
    487
    Austell, Georgia
    anyone.... anyone.... Bueller.....
  3. florida4x4
    florida4x4 1/2 ton status
    Sep 9, 2002
    255
    Florida
    if youre just looking to spend lots of money then go for it. otherwise get a 40 buck Hayden at the local parts house and install it infront of your rad.
  4. Hardcore
    Hardcore 1/2 ton status
    Apr 25, 2003
    458
    New Orleans, LA
    The fan is overkill, all you need is a big cooler /forums/images/graemlins/cool.gif
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    If you ever drive it in cold weather you will need the tranny fluid to go the the radiator first. Just like an engine you need to get the tranny fluid up to temp.
  6. georgiared84
    Sep 5, 2002
    487
    Austell, Georgia
    That's something I haven't thought about. Man... and I got all excited about the cool fan and everything! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif I've got a 30,000lb cooler in front of the rad. now for the trans. It doesn't ever really overheat, just thinking about lightening the load on the radiator for the 383. Oh well, I'll just leave the trans fluid going through the radiator and put the cash into a four row.
  7. mudtruck
    mudtruck Registered Member
    Apr 2, 2003
    14
    pa
    I am running one of the permacool set ups with the electric fan. On the older trannys they work pretty well but i had it on my dodge and it cooled the tranny to much. Dont worry the dodge is long gone. I had to many problems with it and it was a 2000. I would rather run the 77 anyway. Any way if you have the extra money i would say go ahead and buy it. If not i would just run the biggest cooler you can fit in front of the radiator.
    Hope this helps you make up your mind. /forums/images/graemlins/grin.gif
  8. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Adding extra cooling capacity isn't a bad idea. If you place it in series but after the radiator and equip the fan with a thermal switch, you can use the radiator to warm up the tranny and the B&M to cool it even if the engine overheats. You could still overheat the engine though if the tranny overheats but it would take longer. I'm in hot climate where we bypass the radiator all together and keep them seperate.
