trans crossmember for a K30
Discussion in 'Parts & Trucks Wanted' started by crazykev4x4, Feb 4, 2004.
  1. crazykev4x4
    crazykev4x4 1/2 ton status
    Jun 30, 2003
    430
    Watertown,Wisconsin
    i need a crossmember for a k30 must be for a one ton .let me know what ya have .
    Kevin
  2. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    check with me next week if ya still need it then...i'm getting my donor stuff should have the Th400 / np205 x-member from a 86 K30
  3. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    Hey Kevin
    Please post up a pic or at least what tranny - t case combo ya got so ya get the right part as adapters changed heights and crossmembers changed styles over the years mostly in the mid eightys
    also to ya might wanna check with Wess ( That K30 guy ) as he is pertty much the Authority on this kinda stuff
    Hope it helps
    R
    R
  4. crazykev4x4
    Jun 30, 2003
    430
    Watertown,Wisconsin
    sorry its a 78 K30 SM465 Np205
    3Kevin
  5. Larry_in_Tx
    Larry_in_Tx 1/2 ton status
    Oct 24, 2002
    404
    Houston Tx.
    I’m probably no help here but I ended up with a crossmember out of the ’85 M1008 I got my axles from. I doubt it will work for you but I figured I’d let you know it’s out there.
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    The M1008 crossmembers will work in place of the older '78 models easily. /forums/images/graemlins/wink.gif
  7. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    I have one from an 82 k30 400/205 mount..pm me if interested.\
    -Shawn /forums/images/graemlins/waytogo.gif
  8. Bushwhacker
    Bushwhacker 1/2 ton status GMOTM Winner
    May 13, 2002
    796
    Indian Trail,North Carolina
    I have one on a V3500 frame in the back. It had a 465/205 combo in it. PM me if interested.
    Clay
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    Clay
    Won't work. A '78 tranny/t-case combo uses a taller adaptor than the newer ones and the crossmember is flatter where your V3500 is a double-hump type and uses a shorter adaptor.
  10. Bushwhacker
    May 13, 2002
    796
    ahhh...thanks for letting me in on that. glad we have guys like you on here that share the knowledge! /forums/images/graemlins/thumb.gif
    Clay
  11. crazykev4x4
    Jun 30, 2003
    430
    Watertown,Wisconsin
    thanks guys I got the one from larry
