trans fluid in t-case
Discussion in 'The Garage' started by moose73, Jul 6, 2003.
  1. moose73
    moose73 Registered Member
    Apr 11, 2003
    22
    chatt,tennessee
    have trans fluid in tcase, have taken apart and cleaned up shaft then put 2 seals in, it held for a little while but is still getting in there. any suggestions on a fix. its a 73 th350 with 205 combo.
  2. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    umm i thought automatic trany fluid did go in the t-case last time i checked!? maybe i reads it wrong.. /forums/images/graemlins/thinking.gif /forums/images/graemlins/confused.gif
  3. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    205's use gear oil not tranny fluid, the Np208/241 use ATF
  4. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ahh ok..hmm never knew that! why is that?
  5. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    205 is gear to gear and atf is not thick enough to perform lubrication tasks required..
  6. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    oh yea...right...the 208 is chain right...
  7. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Theres an o-ring in your adpter thats faulty, do a search. /forums/images/graemlins/thumb.gif
