Trans fluid leaking into my 208.
Discussion in 'The Garage' started by eclipse, Dec 4, 2006.
  1. eclipse
    eclipse 1/2 ton status
    Jan 1, 2005
    1,245
    Sparks, NV
    My new 700r4 keeps going low on atf and the np208 is leaking. I was told that my input shaft seal on the 208 is bad and the atf from the 700r4 is leaking into the 208. Make sense to anyone? I want to make sure this is the problem before I pull the 208 and start changing seals.
  2. Storm Trooper
    Nov 24, 2000
    4,640
    Easy way would be to check the 208 to see if it's over filled.
    Where is it leaking from and does it have a overflow tube or is it
    coming out of the overflow from the top of the TC (with no OF tube).
    Should be pretty simple to check.
  3. eclipse
    Jan 1, 2005
    1,245
    Sparks, NV
    seems to be all wet around where the front driveline shift is.
