Trans. Fluid
Discussion in 'The Garage' started by grindkings, Apr 22, 2005.
  1. grindkings
    grindkings 1/2 ton status
    Dec 24, 2004
    127
    Marshall, Missouri
    I got a simple question for a difficult problem. Can you fill your transmission through the trans. dip stick? Just seems like and easier way.
  2. slimlynn1
    slimlynn1 1/2 ton status
    Apr 9, 2003
    336
    Hamden, CT
    Yes that is the way to fill it. Be sure to check the level with the engine running and don't over fill it.
  3. nemesis_pyros
    nemesis_pyros 1/2 ton status
    Mar 24, 2004
    229
    Winnipeg, Manitoba
    Prolly a really stupid question but what does over filling do to the transmission, Will it harm the transmission.
    Sorry for the newb question but i don't know much about automatic transmissions.
  4. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    if you over fill a auto tranny the fluid can get air bubbles in it because it is to far up in the case theses air bubbles can get into the valve body and cause clutch packs to burn up killing the tranny
  5. nemesis_pyros
    Mar 24, 2004
    229
    Winnipeg, Manitoba
    alright knew there had to be a good reason
    thanks
