Trans Flush
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Skroo, Oct 27, 2002.
  1. Skroo
    Skroo 1/2 ton status
    Jul 13, 2002
    137
    Houston, Texas
    Is there a way to flush the trans out completly without spending 70 bucks at a oil change place. I flooded it out last week but since a filter change won't change all the fluid I still have water in it.
  2. 88k5blaza
    88k5blaza Registered Member
    Oct 17, 2002
    70
    new hampshire
    disconect the trans line that goes to the cooler and fire up the truck in park have soemone watch to see when the fluid stops pumping out and this will completly drain the system in about 2 mins then if you need to flush it with karoseen and refill with fluid. /forums/images/graemlins/k5.gif
  3. Kamots
    Kamots Registered Member
    Oct 9, 2002
    47
    Oklahoma
    Seems you have to decide whether to spend the money on a flush, or buy alot of ATF an keep dropping the pan an changing it. I would think 4 or 5 drops of running the ATF thru would do it. But i would also check your local parts house an get an additive for the fluid. You might also do a search on a flush kit, i dont know of one but yea never know these days.
    Oh btw if you're going to go the route of dropping the pan that much an drain plug would make sense. Just my thoughts....
    Kamots
  4. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    everything you always wanted to know on tranny care & feeding: #1 Son Sub Page /forums/images/graemlins/thumb.gif
