trans help!! asap!
Discussion in 'The Garage' started by blazin83, Oct 16, 2006.
  1. blazin83
    blazin83 Registered Member
    Mar 6, 2006
    18
    atlanta Ga
    i think i need a new tranny, its not shifting out of first.. all of the oviouse things were checked and still no go.
    so my question, can i take a "standard" 2wd turbo 350 or even a 700r4 and bolt it to my 4wd tail shaft and everything work???
    i reaaaalllyy need help soon guys i need to drive to school first thing in the morning!!
    thanks!
    its a 83 350 with a turbo 350 tranny
  2. dyeager535
    26,977
    You got reverse too?
    There was just a thread that resurfaced about this, the governor gear was ground down. Fairly easy fix and easy to check too. Large round steel (not aluminum) cover on the driversside of the trans, towards the rear. Might have a metal clip over it. Pull it and pull the governor out.
  3. blazin83
    Mar 6, 2006
    18
    atlanta Ga
    awesome, ill go check that out!
    thanks man!
