Trans Install
Discussion in 'The Garage' started by ProJunkRacing, Nov 30, 2005.
  1. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    Ok I am being screwed here and really pissed but just wondering how to get this damn thing in
    oh 6" Lift With 38.5's And it is Currently Sitting on those tire skates
    I got an 86 K20
    350 465 205
    I got the trans out with one jack and like 5 jackstands now I need to put it in and am looking for strategies to do it
    I have One Floor Jack
    2 6 Ton Jackstands (Tall)
    2 2.5 Ton Ones ( Medium)
    2 2 Ton Ones (Short)
    No Engine Crane ( I wish)
    Any Ideas
    If So
    Call Me Or Post Something I Live In Frankfort Il If anybody is close
    (815) 274 -4680
    ALl I can say is it sucks having one jack , and it not being a trans jack.
    Philip
    Oh Bell Housing Is on the motor right now
  2. dyeager535
    26,980
    6" lift, wheel skates, how much clearance frame to floor would you have if you pulled the tires off? Even without doing that, pulling the tires off and using jackstands, one corner at a time, should get you to a reasonable height.
    My '86 you can't remove the trans tunnel without some spot weld cutting, yours I'm assuming is the same.
    The 465 is a bear to get in because the bellhousing hits the motor before you get the trans far enough forward to clear the shifter tower on the floorpan. Really need it low enough that you can manhandle the trans, but having a floorjack to support your efforts helps, and I suspect with the 38's and 6" lift, that's a long ways off the ground.
  3. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    yeah i got it strapped to the jack with stands now just need to slide it in i wish it was easier then it sounds lol
  4. darenofears
    darenofears Registered Member
    Jan 25, 2005
    47
    Indiana
    You could Always pull off the cab first
    :haha:
  5. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    no thanks lol
  6. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    I went threw the same crap that you are going threw. I said F it and went out and rented a tranny jack.
    Adam
  7. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    how much did that cost ya?
  8. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    i had to install a 350 trans and 208 tcase on an 88 with sas and 4 inch lift by myself with a ****ty floor jack. my suggestion is get a trans jack and a friend.
  9. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I would suggest getting soemone to help also. If you were closer than 1 1/2 hours away i would be there.
  10. merace19
    merace19 1/2 ton status
    Sep 19, 2003
    372
    Mobile, Alabama
    I ran two straps from frame to frame under the trans and transfercase. I tighten them up a little at a time and i got a 400/208 back in 4 times. All by my self. I did have a floor jack and blocks of wood to help lift. It can be done. I fogot the spacer that goes between the motor and trans then when i thought i had it. The thing had dropped on the other side. Thats why i had to install it 4 times.
  11. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    aha well it is somewhat in but sitting under the rig on 4 jackstands it is just so much harder being a manual transmission i just have nobody to help so it will sit till either my dad helps or somebody else can
  12. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,026
    855
    Pinckney, MI
    I got quoted 20 bux a day for a trany jack that would lift about 34" and your about 1.5 hrs away or I'd be all about helpin ya too. I may be able to help next weekend after all my finals are done.
  13. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    ive helped do 4 tranny swaps, puttin them back in is a bit**. what we did was use a jack and made a wood thing to put on top so that it would get more height to get up there, he had 6" and 35's. after about 30min of struggling we got it in. same thing for the t-case, cept didnt take as long.
    get the tranny jack if u can
  14. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    that would be sweet if you could just let me know all my friends wont wrench anymore ,and the ones that do are know it all 's and never want to do anything but watch
