Trans leak in front seal area?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazinBaldy, Oct 23, 2002.
  1. BlazinBaldy
    BlazinBaldy Registered Member
    Jun 10, 2002
    10
    Pismo Beach, CA
    When my trans get hot it starts to leak fluid, but I dont know from where... someone told me that it can be the torque converter or the front seal or the trans pump. Has anyone else had to deal with this... The guy I bought it from just had the trans rebuilt about 2 years ago, so not sure why this is happening so soon. /forums/images/graemlins/confused.gif /forums/images/graemlins/k5.gif
  2. rusty79beast
    rusty79beast Registered Member
    Sep 30, 2002
    64
    Houghton, MI
    I had ATF leaking from the hole in the bottom of the bellhousing, and I am in the process of replacing the front seal. I took the transmission out on Saturday, but didn't have time to put it back in yet. I sure hope that was the problem, because it is kind of a pain to take the tranny out. If you need to take your tranny out and have questions, I might be able to help since it is still fresh in my mind.
  3. dyeager535
    26,982
    191
    What tranny? I *think* the 700's had a "problem" blowing the front seal out like the 200's did.
    In any case, the front seal is no big deal, same type of seal used on GM slip yoke transmissions or transfercases. A screwdriver, flat chunk of wood and a hammer and you'll be all set. After you pull the tranny back far enough to get the converter off of course ; )
    Converter leak is pretty unlikely, although it was GM procedure to drill a hole in the torque converters for some sort of testing or draining, they don't have holes in them normally, except the one that fits into the tranny, which is where the seal that may be leaking sits.
