Trans line flow direction on 700R4
Discussion in 'The Garage' started by Hossbaby50, May 7, 2003.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Is the top line the sending line for the cooler lines on a 700R4? I forget, and I have to install my external tranny filter tomorrow. Thanks
    Harley
    P.S. I did a quick search and couldn't find it.
  2. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    on my '88 K5 the top line coming out of my radiator is the return line. what you can do to double check is disconnect one of the lines from the radiator and then start the truck and put it in drive for about 3 seconds and put it back in park and shut if off. then look to see if the tranny fluid came out of the radiator or the fluid line. if it came out of the radiator it's the return line, and of course if it came out of the tubing, it's the line that feeds the radiator with fluid. hope this helps. /forums/images/graemlins/thumb.gif
    rick
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Yup.
  4. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    so , does the top line out of the radiator go to the top
    line on the tranny?
    i have been wondering if i hooked mine up right after i put my tranny back in /forums/images/graemlins/confused.gif
  5. heavy4x4
    Aug 28, 2002
    3,270
    Yes, I believe it does.
  6. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Let me rephrase a little. Is the top line out of the tranny case the sending line? Or is it the bottom line? Thanks
    Harley
  7. heavy4x4
    Aug 28, 2002
    3,270
    I THINK the bottom line out of the tranny is the sending line.
    But, now that you know the information about what line is which on the radiator, you could always follow one of the lines back - do that just to be sure.
