Trans mount?
Discussion in 'The Garage' started by ktedesco, Jun 9, 2004.
  1. ktedesco
    ktedesco 1/2 ton status
    Mar 21, 2004
    365
    Colorado Springs, CO
    My transmission/transfer case bounces alot more than I think it should. It also makes a clunk sound during a hard shift. I ordered a poly mount for it through ORD and it should be arriving tommorow. Hopefully this cures the problem. I guess the next step is motor mounts.
    Question is, I can't find any info on replacing the mount. Is it as simple as it looks? Put a jack under the transfer case, raise slightly and support, remove old mount and replace with new then remove jack. I just don't want to run into anything unexpected (yea, right /forums/images/graemlins/whistling.gif). Thanks all!
  2. 82K5_6.5L
    82K5_6.5L 1/2 ton status
    Dec 4, 2002
    439
    Tucson, Az
    when i was replacing a seal on my tranny, i replaced the mounts as well. its easy, just drop the crossmember (due to you having more room to work on it) and just put the new ones on. slap it back up, bolt it on and goooo.
  3. evilk5
    evilk5 Registered Member
    Oct 20, 2003
    94
    LITTLETON, CO
    Kevin thats about it, no tricks pretty simple. At least it was easy on the 71 /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/waytogo.gif
  4. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I would advise against installing just poly trans mount without the corresponding poly motor mounts or vice versa.
    The difference in the movement of the poly and the rubber, esp with old rubber mounts can cause your tranny or adapter to crack. Not fun! /forums/images/graemlins/doah.gif
    Just my .02,
    John
  5. ktedesco
    Mar 21, 2004
    365
    Good point. Never thought about that. I could see how that could happen. I probably should the poly engine mounts also. They are alittle pricey though.
