Trans oil cooler
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by snowtoy, Sep 5, 2001.
  1. snowtoy
    snowtoy Registered Member
    Mar 18, 2001
    30
    Norway
    I'm using mine K5 towing sometimes, will original oil cooler in radiator be good enough, or do I have to change it with a new one, size?
  2. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    Go look at Gokartergo's post about a week or two ago. He got one for $50 from Summit...
    KEN
    DANGIT it's not a bronco!
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    If you're towing and your truck has a 700r4 tranny, an auxilliary cooler is MANDATORY!!!! 700r4s hate heat and will self destruct, especially if you're towing heavier loads.
    I have a TruCool(made by Long Inc.) cooler with a 22,000 GVW rating. It was a breeze to install and works great. Make sure to run the aux. cooler in series with the rad tranny cooler. Also, try to buy a stacked plate design- the old aluminum tube/fin designs aren't as efficient or tough.
    <font color=blue> MEAN DAD WITH TWO BAD KIDS<font color=blue>
  4. snowtoy
    Mar 18, 2001
    30
    Norway
    I have a rebuild Th 350, I have a cooler who I can use but not sure how big it is.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I would like to 2nd CanmoreK5's post. Get the largest stacked-plate cooler you can find. I use a 24,000 lb. one with my 700R4. I pull a 4,000+ lb. 25' travel trailer with my truck, with no problems, even with the 35" tires.
    A TH 350 doesn't have a lockup torque converter so I'd think it's almost as important to have it on there as it is the 700R4.
    Tim
