Trans problem>>>>>(th350)
Discussion in 'The Garage' started by bbck5on37s, Jan 14, 2007.
  1. bbck5on37s
    bbck5on37s 1/2 ton status
    Jan 3, 2007
    543
    Denver Colorado
    I have an 82 K5 w/ about 7" of lift and some 37" IROK's.
    it was running like crap so i put on a new carb.... it wasent shifting right so i looked and found the tv cable has came disconnected from the carb....I put it back on and it shifted better but it shifted at arond 3000 rpm.. i was playin around in the snow today and it started acting funny again....when is shifts into second gear it acts as there has been a big load put (like your towing up a big hill) on it and it slows way down.....i checked the trans fluid and it seems ok....I cant figure it out and i want to get it fixed so i can hit the trails......:confused: :doah: :mad: bbck5on37s@yahoo.com
  2. sunnyc123abc
    sunnyc123abc 1/2 ton status
    Mar 12, 2005
    636
    SoCal
    Vacuum line maybe:dunno:
  3. bbck5on37s
    Jan 3, 2007
    543
    Denver Colorado
  4. CB77GMC
    CB77GMC 1/2 ton status GMOTM Winner
    May 6, 2005
    771
    Heath Springs, SC
    Sounds to me like a vacuum modulator gone bad if it is a th350. TV cables I have only seen on 700r4. If TV cable was not hooked up = not good. :confused:
  5. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    I don't think your TV cable has anything to do with it. unless it's tooo tight. But I think it would just stay in second.:dunno: MABY I'm running my Th350 with the TC cable unhooked it's fine I just have to downshift by hand.
  6. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    th350s dont have a tv cable. the thing you are refering to is the kickdown cable that causes the tranny to down shift when there is a load on the motor such as pulling a steep hill and you have to give it more than say half throttle depending on how the cable is adjusted. my vote goes for the vaccum modulator. its what controls the shifting on th350s and th400s.
  7. dyeager535
    26,977
    Vacuum modulator controls shift firmness (and can change shift RPM slightly based on vacuum) the governor handles shift points.
