trans problems with Turbo350
Discussion in 'The Garage' started by cojnit, Mar 24, 2003.
  1. cojnit
    cojnit 1/2 ton status
    Jul 23, 2002
    178
    Hawthone, CA
    Having problems with my 350 trans. It wont shift into 3rd. It will shift sometimes, if I mess with the shifter and move it from second to third. I am a not so mechanically inclined wheeler. I did manage to change the transmission filter in hopes that this may be the problem. No Help. also checked the vaccum line, it also looks okay.
    Any thoughts??
  2. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Sounds like a linkage problem.
    My friend was having a similar problem in his 90 K5, that was just the shifting linkage on the tranny needed to be adjusted just a little.
    I like changing to a cable and floor shifter instead of rod type linkage and the column shifter. /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  3. cojnit
    Jul 23, 2002
    178
    Hawthone, CA
    correction, the shifter needs to be played with in order to move into second gear as well. you think it could be the same thing? There were no changes made when this happened, just started. Actully now that I think about it I had the front seal for the oil pan go at the same time! Coincidence??
