Trans swap 2
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rockin'g_racing, May 20, 2000.
  1. rockin'g_racing
    rockin'g_racing Newbie
    May 18, 2000
    Brooklyn, MI
    If the TH350 was offered on 85 and earlier Blazers why would swapping a TH700R4 for a TH350 be very hard?
    if i found a trans out of an older Blazer it should be a snap.
    Besides you can't tow with 700R4 in 4th gear.( owners manuel says not to.) And you can't put a very big cam
    in and make it lug in 4th.that's why i want a 350.
  2. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    That swap shouldn't be too hard, you might need a new crossmember, though. And of course it's a good idea to get a new torque converter(the 700-r4 one won't work).
    This said, why not go ahead and put in a TH-400? The TH-350 isn't really any stonger that a 700-R4 in the same condition, so you won't gain and strength. By going to the Th-350, you'll also be getting a higher first gear, something you don't want for towing!
    I used to have an '85 with a 700-R4 with big tires. I didn't use the overdrive much, but I sure liked having that low first gear!
  3. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    you can tow and use a cam with the 700r just use the 87 or later as it had all the little problems fixed!
  4. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Yes, you shouldn't tow a large load with a 700r4 in overdrive (4th gear). So you put it in 3rd gear which is exactly the same as 3rd gear in a TH350....so no difference there.
    I also don't understand the big cam problem with a 700r4.....
