trans/t-case "ringing"
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by yeild2me, Sep 8, 2001.
  1. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    trans/t-case \"ringing\"
    ok, my truck makes this gear/whine/ringing noise at hiway speeds, so i jacked it up and ran it up to 65 mph on jack stands. at about 50/55 the ringing started and comes from my trans/t-case. its pretty loud, but not deafing! does this mean that my 160000 mile drive train may nearing the end of the road?? i have a 700r4/np241/14 bolt
    350 TBI, 700R-4, NP241, D44-14FF, 4:10's, 38.5 TSL/SX's, full conv., full cage
    <a target="_blank" href=http://www.yeild2me.rockcrawler.com>www.yeild2me.rockcrawler.com</a>
  2. 1975k5
    1975k5 Registered Member
    Feb 28, 2001
    44
    Alabama
    Re: trans/t-case \"ringing\"
    last year i owned a jeep commando with a ringing coming from the rear axle. it turned out to be the ring gear and pinion were severely worn and loose. i would say your drive train is approaching its lifespan.
  3. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    I'd go for cheap first, and change out the U-joints....they can cause a ringing sound that seems like it is coming from somewhere else.....also, check your tranny mount....bad mount can torque your driveline outta line, and drive ya nutz tryin' to find the prob.....(been there, done this).....good luck.....JD
    Stuck?...Hell no..I still got some gas left..
  4. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Ditto on the u-joints[​IMG]
    1 tequila 2 tequila 3 tequila Floor
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
