Trans Temp Gauge
Discussion in 'The Garage' started by justpushplay, Jan 15, 2004.
  1. justpushplay
    justpushplay Registered Member
    Oct 26, 2003
    14
    Metro DC and Southern MD
    For an 86 with a 700r4. I don't know the first thing about them, how does it install and where can I buy one? Also, what would be considered a normal tran temp operating range.
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    The last one I had came with a 'T' that spliced into the hard line from the tranny to the rad. The 'T' had a sender unit on it that was wired direct to a gauge. Think I got mine from Summit. Don't remember the op. temp as it was on a previous truck and I don't have one on this truck...yet! /forums/images/graemlins/thumb.gif
  3. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    The one I have installs right in the side of the tranny pan.
    I used a drain plug kit because it threads right into the plug on mine.
    From what I've understood, about 30 degrees below what your engine coolant runs is what your tranny should be at.
    Hope that helps ya some. /forums/images/graemlins/thumb.gif
  4. mccomas
    mccomas 1/2 ton status
    May 30, 2003
    262
    Fayetteville, NC
    i have always been told to keep tranny temp under 190. i ran a temp gauge on my ram and it stayed around 170 to 180 with a stock cooler...
  5. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    from what I understand you can even run a regular coolant temp guage for tranny temp. Just install a fitting into the tranny fluid pan and hook it up.
  6. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    Have one in my 91 sub.. (B&M).. here's a little more info on it.. ( go thru Home >Transmission Products >Transmission Temperature Gauge ) and then Tech Info....
    B&M
    If you look close @ gauge, it shows the 'acceptable' range.
    (added a whopping cooler to mine, and seldom get to 150 now on the return fluid temps. Going to add a 2nd one to get the 'exiting' tranny temps to see how effective it is.
  7. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I installed mine in the pump pressure test port on the drivers side of the tranny. It is a 1/8 NPT just like my trans sender (autometer). At this location it will read the temp after the pump but before any of the coolers. It makes for a very clean install and you don't have to use any special adapters or weld a fitting into the pan. My temp runs about 175* with the factory and aftermarket cooler.
  8. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    On what tranny? I'm looking to install one on my burb soon (TH350) and am looking for the best place to install it.
  9. the excuse
    the excuse 1/2 ton status
    Dec 9, 2003
    209
    san diego
    i got the autometer performance series trany gauge. the sender comes with a whole bunch of brass fittings so it can be screwed into many different size holes. the fittins let the sender screw into themselves then you screw the fittings into the right aplication. i drilled a hole in the side of the pan and sandwiched the pan inbetween the sender and a larger fitting. then i jb weilded the outside part of the pan. when yo do this be sure the sender has a good ground if it dosnt it will read wrong or not read at all.
  10. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    That was on my s10 with 700r4. The TH350 is in about the same place at the transition from the body to the bell on the drivers side. The TH350 might be a 1/4" NPT so you might need an adapter...I don't remember. Most of the other test ports are farther back and clumped together so I don't think there is any way to confuse them.
  11. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Thanks /forums/images/graemlins/thumb.gif
  12. lukebaby1
    lukebaby1 1/2 ton status
    Dec 16, 2003
    231
    Richmond, Virginia
    cool /forums/images/graemlins/thumb.gif
  13. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Got a pic or description of that port?
  14. chevystepside
    chevystepside 1/2 ton status
    Sep 23, 2002
    147
    leadville colo
    i was looking at my 700r4 that i,m going to rebuild. that plug or port are talking about is that the one just above the shifter linkage on the lefthand side of the bell housing?
  15. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I thought my previous description was good /forums/images/graemlins/tongue.gif
    Does this help /forums/images/graemlins/thumb.gif
  16. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    I thought it was a good description /forums/images/graemlins/thumb.gif
  17. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    I was so excited I must have blown right past it or posted without seeing it /forums/images/graemlins/grin.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif
