trans temp guage
Discussion in 'The Garage' started by boots, Feb 17, 2003.
  1. boots
    boots 1/2 ton status
    Nov 3, 2002
    183
    Foothills of CA (Mariposa)
    am looking at making an inline temp manifold for my trans (th350). I am having trouble finding a transtemp guage locally for a decent price. My main question is whether or not a standard oil temp setup will work or not. I'm assuming I should mount this as close to the output fitting of my trans rather than up near the coolers or even after the coolers. anyone know off hand what size/pitch those oil temp sending units are for the most part?
    thanks
    me
  2. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    Ant standard oil or even a water temp gauge will work for trans temps. Sending unit only sees temperature not whether it's in oil or water. Most sending units are a pipe thread size of either 1/4" pipe or at most 3/8" pipe. I've seen very few in 1/2" pipe. They should be mounted as close to the source of "heat" as possible, usually in the oil pan.
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    a search on the topic will give you lots of great info.
  4. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    I bought my gage(autometer)from Summit and also bought a external spin on trans oil filter unit. Use a trans temp gage it has a lower temp range. It has a hole where you can mount the sending the sending unit and also has a spin on filter. I plumbed the filter to the trans outlet tube so it gets the highest fluid temp. I had the sending unit on the drain plug but pulled the wire off out wheeling so I killed three birds with one stone, got a better location, better filter and added another quart to the system to help cooling. Plus I did not have to hack up any lines. /forums/images/graemlins/thumb.gifLater Slider
