Trans temp question
Discussion in 'The Garage' started by dheavychevy38, Jul 4, 2005.
  1. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    I am putting a fresh 700r4 in my k5 and was wondering where is the best place to mount the temp sender so i can have a idea of how hot it is running thanks Denny
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    tranny pan
  3. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    Thanks i will drill and weld a nut in there for it thanks agoan. Denny
  4. seschev3
    seschev3 1/2 ton status
    Jan 19, 2005
    308
    clayton, ca
    You can buy a B&M bolt in kit. Just drill a hole in the pan and put the bolt in with the nut in the pan. Comes with rubber washers to seal it. Or you can drill and weld the nut like you were going to. I have an aluminum pan so I drilled and tapped in the center rear of the pan. Make sure you check for clearence in and out of the pan.
