Trans temp sender install/Brazing how to
Discussion in 'The Garage' started by k20, Jul 20, 2006.
  1. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    What is the best way to install a trans temp sender in a cast alum tranny pan? Read one place said might be able to drill & tap a hole, pan is ~1/8th thick, just doesnt seem like enough thread engagement to me.
    Other thing I saw was brazing it in. One thing I see says you need an oxy-acet torch, another says a propane torch (I got one of these lol), and the list goes on to something that says just to JB Weld it in.
    If I were wanting to braze it in, what do I need to get (rod/filler/flux) and can it be done with a propane torch? What would the procedure be? Its a brand new pan also.
    Thanks.
  2. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    maybe drill and tap it and find a nut that you can loctite inside of the pan? or drill/tap and jb weld?
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    drill and tap
    wouldn't want to practie my brazing on a cast aluminum trans pan(usually not cheap)
  4. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    I would think anything higher than 300* will fry the sender!
    B&M makes a sender with their tanny temp gauge, also Autometer, VDO etc.
    Bottom line, they are threaded, probably all 1/8 NPT. You could cut and thread the pan.
    If the pan already has a drain plug, the B&M pan plug kit has a bung for the pan, and an 1/8 NPT drain plug. The B&M sender can swap for the B&M drain plug. Thats whats on mine.:D
  5. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Yeh I just didnt know about how strong that pan would be threaded, thats probably what Ill do now that I think about it, dont really wanna be melting the pan. Dont really wanna use the drain plug, because it threads in the bottom, and I see the potential to rip it off, and I already have poor luck with transmissions.
  6. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    How about putting the sender in one of the tranny lines?
    Cut a line, or plumb into it where it feeds into the cooler, and tee into it.
    This is what the B&M tranny temp gauge kits use.
    Yes, you should know what temperature your tranny is, not the cooler, but my feeling is that I know where on the gauge is normal for my truck, and past that is bad, regardless of where the sender is plumbed or what the precise number is :)
    -- A
  7. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    That is what I did. I got brass fittings from NAPA then I used silver solder and brazed them together with my ox/ac torch.
  8. Dallin
    Dallin 1/2 ton status
    Feb 12, 2003
    135
    Thread the sender into the pressure port on the side of the case. If you really want it in the pan then weld in an aluminum NPT bung. I've never had luck trying to braze cast aluminum.
  9. diesel4me
    Jul 24, 2003
    17,540
    930
    Massachussetts
    cant braze aluminum!!...
    You might be able to solder or TIG weld aluminum with the right rods,but brazing is for ferrous metals like steel or iron only!--(the instructions assume your installing it in the OEM tranny pan made from steel)..
    Only way to "weld" aluminum is with a TIG welder,or a MIG with aluminum wire--there is a kind of solder,you can use with a propane torch called "Rub-On"..I've had very limited sucess with it--works great on canoes,beer cans,aluminum tubing like that found on A/C condensors..but doesn't work very well on small engine cases,the main reason I bought some!..:crazy:
  10. Dallin
    Feb 12, 2003
    135
    diesel4me do a quick google search and you'll see there are brazing rods and fluxes for much more than just "steel or iron". Aluminum can be brazed with the right materials. My few feeble attempts at brazing cast aluminum went poorly. Maybe someone else has had some success
  11. mrk5
    Apr 20, 2004
    12,331
    1,039
    Northern Colorado
    I second this. I put mine in the line going out to the cooler. I figure that should be the hottest temp because it has gone all the way through the torque converter.
    I used this to hook it up:
    Pretty simple since it uses compression fittings.
    It's called a temperature manifold and it's made by Autometer. There's one for 5/16" and 3/8" tubing.
  12. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    What came with the gauge kit?
  13. diesel4me
    Jul 24, 2003
    17,540
    930
    Massachussetts
    yup...
    I'm aware there are fluxes and "brazing" rods for aluminum,and other non ferropus metals..I was assuming he was referring to brass brazing rod like you'd use on steel or iron...I'm sure the brazing of aluminum and other non ferrous metals is an art form,that most do it yourselfers won't have much luck doing!...
    I've seen guys use a large nut and bolt thru the pan,using fiber washers to prevent leakage--they drill out the center of a big bolt,like a 3/4",and tap the hole with the correct threads to receive the sending unit..have to make sure there is enough clearance ,to ensure the head of the bolt wont interfere with any internals of the tranny....:crazy:
  14. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
  15. sweetk30
    Nov 1, 2004
    25,536
    533
    horseheads , ny 14845
