Trans to Transfer Adapters
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jaybird, Dec 27, 2001.
  1. jaybird
    jaybird Registered Member
    Nov 16, 2001
    21
    Arlington, Texas
    Do the TH700R4 and the TH350 use the same transfer adapter? I found a fixed yoke NP205 that will be free if it will even swap.
    Jay VT
    79 Jimmy 454, 700R4, NP208, D44, 14 bolt, 4.56:1, 38's
  2. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    I don't know. I have a picture of the adapters for TH350, TH400 and an SM465. But unfortunately, I do not know whcih (if any) of those fits a TH700R4. I can email the picture to you if you want though.
    A computer once beat me at chess, but it was no match for me at kick boxing.
    <a target="_blank" href=http://photos.yahoo.com/dana60manual>http://photos.yahoo.com/dana60manual</a>
  3. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I researched this swap and found that yes the th350 adapter will work but the output shafts on the 2 trannys are different so you will need a conversion tailshaft. Otherwise advanced adapters I believe makes something to adapt them together
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  4. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    If the t-case, adapter, and drivesleeve (27 female spline) are from a TH350, it will work but you will have to get a new output shaft for the 700r4 which requires a teardown of the tranny (advanced adapters sells the correct adapter, which is actually a new output shaft) or get a spacer that goes between the transmission and the adapter, but it adds significant length. The advantage of the spacer is that it gives you more room for front driveshaft clearance. The 700r4's pan kicks out quite a bit on the passenger side and when it is coupled to an NP205 can create clearance issues. Several people who have this combo have had to alter the tranny pan to keep the driveshaft from hitting. Some pound the corner in, and some cut and reweld the pan, which is the route I chose because I had them mated with the correct output shaft in the tranny rather than using the spacer..
    See my rig at <a target="_blank" href=http://coloradok5.com/gallery/Leadfoot> click here </a>
