trans/transfer
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by motorheadnelson, Aug 12, 2001.
  1. motorheadnelson
    motorheadnelson Registered Member
    Aug 12, 2001
    80
    Fort Mohave AZ
    What's a good trans/ transfer for a big block swap? Truck in mind is a 73, building a 500+ ft/lb motor, prefer later model OD. Crossmember/driveshaft fab OK if needed...I'm new here, but chevyfumes is my weekend 'play trucks' bud (as his wife says). Have 4:10's, 35's, locker...Converter suggestions?
  2. 502Burban
    502Burban 1/2 ton status
    Jun 8, 2001
    379
    Southern California
    If you prefer later model OD, and will be twisting with 500+ lbs of torque, you probably will want to run a 4L80E. They aren't cheap, but they will be up to the task. Jet Performance makes some nice ones, as does TCI and others. You will also need a computer to control it.
    Robb
    '73 GMC Suburban - 502DFI
    <a target="_blank" href=http://community.webshots.com/user/robbrj>community.webshots.com/user/robbrj</a>
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yeah, I agree. Use the 4L80E for your automatic choice and use the NV4500 for your manual choice.
    I would use either the NP205 t-case or the Atlas II, which has 2 options of low range.
    <font color=blue>Daddy told me while learning to pee......"if you shake it more than twice, then you are playing with it!!!"</font color=blue>
