trans vacum line
Discussion in 'The Garage' started by RATAH, Nov 3, 2002.
  1. RATAH
    RATAH 1/2 ton status
    Aug 10, 2002
    576
    Franklin,Ohio
    where does the vacum line goto on the motor?
    also if ya have a pic that would help
  2. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    Between the distributor and the carb.......that's where my 77' comes from the factory.......I really don't think it matters where the vacuum comes from.
  3. The vac line running to the modgulator on the trans, dose usally run from a T in the intake manifold behind the carb. But it realy dose not matter were it comes from as long as it's a manifold vac sorce and not venturie vac sorce. to test for manifold vacume install a vac gage or your finger over a vac port and with the engine ideling you should have vac, when you snap the throtle the vacume will droop off sharply. Happy shifting.
  4. RATAH
    Aug 10, 2002
    576
    Franklin,Ohio
    Thanks guys,
    almost done, time to break out the
    SAZZALL,the exhaust wount go thru the cross member now gotta
    cut it off
    I love power tools /forums/images/graemlins/smile.gif
    Looks like i can get Dual exauhst now,
    what kinda mufflers would you guys recomed?
    also what size tube?
