Transfer cas
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by detailer03, Jul 31, 2004.
  1. detailer03
    detailer03 1/2 ton status
    Sep 23, 2003
    108
    Arizona
    I have an 89 K5. What are the warning signs of a bad transfer case vs bad trans. When I put it in reverse, it hestates and jumps.
  2. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    That would indicate transmission not transfercase. Transfer case don't care which way you turn it. All gears and chain.
  3. detailer03
    Sep 23, 2003
    108
    Arizona
    Are there any noises or other things that might indicate a bad tranfer case.
  4. bigredk5blazer
    bigredk5blazer Registered Member
    Jul 11, 2004
    11
    Newark, Delaware
    Why do you suspect that the t-case is bad? Basically they don't have a high failure rate, except if the truck is lifted, with bigger tires, and high horsepower. An '89 would have a 700R4 trans and an NP208 t-case. I'd be a lot more likely to suspect trans problems than t-case problems.
  5. xtrmjoe
    xtrmjoe 1/2 ton status
    Aug 3, 2004
    330
    Boonville, CA
    could be slop in the chain of the t-case.
