transfer case clearance
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Nonesuch, Apr 29, 2002.
  1. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    I am running a th350 and np208 and i cant stand the clearance of the 208. So what can I do to increase clearance? Will a 203 or 205 offer more clearance? I want less of my t-case hanging below my frame.
    Justin
  2. bherring
    bherring Registered Member
    Nov 2, 2000
    55
    VA,USA
    It looks like maybe you could rotate it. Anyone done this?
  3. XtrmChevy
    XtrmChevy 1/2 ton status
    Jul 14, 2001
    148
    Finland, Europe
    I have done it and I know of others too. It is not really hard to do. You have at least to drop the case and then make one of the boltholes in the adapter "longer or wider" by mabe 1/2" because the distance of two holes is not the same as the others.
    Confusing? I mean five holes will bolt right up but not the sixth.
  4. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    Skyjacker has an indexing ring for lowering the NP241 on the Dodge Ram trucks when a lift is installed. Looked real easy to make to clock the t-case up. Just have a ring cut out of 1" steel plate that's more or less the same pattern as the adapter. Use the adapter for a guide & drill the holes to bolt the ring to the tcase. Then; rotate it the number of degrees you want to clock the case & then drill the pattern again only this time; you tap threads into the ring. Then; you bolt the t-case back up threading the mounting bolts to bolt the t-case & ring to the adapter. /forums/images/icons/smile.gif
    If I didn't have such extreme angles on my front driveshaft now; I might do that. If I decide to lower my engine mount & level out the engine/tranny/t-case; I will be doing it. /forums/images/icons/laugh.gif
    Good Luck
  5. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    if you end up trying something...let me know. i would love to get more tc clearance and i could meet up with you somewhere.
  6. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    Does anybody have any pics of this?
  7. Nonesuch
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    I am going to figure something out. I got tired as hell draging my t-case over everything I crawled over this past weekend. When I had the tranny out last week, I didnt see a solution but I also wasnt really thinking about it. Now its bugging the pee out of me, its all i can think about!
    Justin
  8. Nonesuch
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    i will look into this. I only have four bolts on my adapter. I am not sure if this will work with my setup! Were you running a 700r4/208 combo?
    Justin
  9. XtrmChevy
    Jul 14, 2001
    148
    Finland, Europe
    Oh yea I have 400/208 but I meant the six bolts that keep the adapter to the case, not the bolts from the adapter to the auto. Or is it different on 700/208? A friend of mine did this on a 86 Blazer and it worked. It turns the case 1/6 of a turn up and it gets just about flat.
  10. txbluethunder
    Jan 29, 2002
    835
    Austin, TX
    take some pics!!!
  11. XtrmChevy
    Jul 14, 2001
    148
    Finland, Europe
    Not able to. Damn I just have to get a digital camera!!
