Transfer case drop kit??? Yes No?
Discussion in 'The Garage' started by ntx78k5, Dec 23, 2005.
  1. ntx78k5
    ntx78k5 1/2 ton status
    Oct 22, 2004
    166
    Home of the Rangers
    I currently have a spacer kit on my 203 and in the last year have developed leak after leak. If I remove this with a 4" lift will I be ok? Right now it drives and runs fine. But I equate the leaks to the added pressure from the tranfer case drop.
    Anyone have any experience either way?
  2. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    well if it fixes your leak id say yes if it all works ok... I got a drop on my truck... 6" susp and 1" zero rate in the front.. I got leaks.. but gonna rip my motor out and fix them...
  3. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    Dont think the leaks are a direct result of the tcase drop. You might have a crack in the case, or a gasket/seal might be broken.
    The tcase drop is to give you a better driveline angle on the rear. It usually makes the front worse though. If you need to drop it, dont use the spacers they provide. They put some major stress concentrations on the frame. Space it down with some square stock between the bolt holes.
    I have my crossmember spaced down a bit, but just temporarily until I can get a CV made.
